Hull newbie with a 6volt c90
Re: Hull newbie with a 6volt c90
All your bike is DC.
Its the only version of a C90 that is
- Rides:: Honda c90 6v
Wooooohooooo it's alive thank you! Although it cuts out when you Rev it! Is that because there's no air filter on it Now to work out which wiring loom I need
It will be because the carb is a bit gummed up and will need cleaning.
Is it worth cleaning or just buying a new one? I noticed a bit of fuel seeping out where the fuel tap is too
You can't get a new one for your model.......
Really? That's not good! Would it not run properly on a different carb
Clean the original carb.
I'll give it a go
Hi guys started a project thread
viewtopic.php?f=13&t=29456
