Halogen Headlight Bulbs for 12v C90 Cub.....
Fuzz
Post by Fuzz » Sun Oct 03, 2010 4:00 pm
Halogen REPLACEMENT 12v Bulbs for C90 Cubs....
NOW back in stock.
http://www.mildhogs.8m.com/shop.html
Newtsalad
Admin & site janitor.
Re: Halogen Headlight Bulbs for 12v C90 Cub.....
Post by Newtsalad » Mon Oct 04, 2010 12:38 pm
Mine arrived this morning, cheers buddy! :D
Knobby
Rides:: 2007 Honda SH300i
Post by Knobby » Wed Oct 06, 2010 8:29 pm
Just placed an order for head lamp bulb and LED rear bulb
Newtsalad
Post by Newtsalad » Thu Oct 07, 2010 12:59 am
I absolutely do not recommend the LED rear bulb, if you value your life. IMHO, they aren't up to the job. That's not just the ones Fuzz sells, I've yet to see ANY one that's 1/3 as bright as a normal bulb. Just my opinion.
Pjam
SPAMMER!
Rides:: C90, C70c, CB500, ANF125, A100 Bitsa
Post by Pjam » Thu Oct 07, 2010 11:37 am
If you see the Suzuki SV 650 there's about 20 of them in two lines in order to bring up the light level!
Newtsalad
Post by Newtsalad » Fri Oct 08, 2010 8:49 pm
Yeah, we've done our own tests here, and WE know what we see, dark is very dark where we are, middle of nowhere, and we've put bikes down the lane in the dark, side by side, LED and incandescent, swapped 'em & revved 'em etc.etc. and the LED's are pathetic.
I'm not sure I could convince people by videoing it either, because video cameras pick up light the eye can't see. You can demonstrate this by videoing a TV remote control while pressing the buttons, and you can clearly see the light emitted on the video.
On any of the rideouts you'll easily tell who has LED bulbs they glow about as much as a fag butt.
Unfortunately there are a few ardent fans of LED's IMHO they're misguided, and should get two or more bikes together and do proper tests before advocating them.
HOWEVER, I do accept they use far less power, and accordingly, I have one in a Land Rover tail/stop light IN ADDITION to my rear light, in case the main light should fail.
scutter
Rides:: zzr1100 1993 C90
Post by scutter » Thu Oct 21, 2010 11:15 am
Fantastic bulb, I realy cant rate them high enough
dickdastardly
Rides:: c90 cub
Post by dickdastardly » Fri Nov 11, 2011 1:19 pm
digger06
Post by digger06 » Fri Nov 11, 2011 3:11 pm
i just bought one, what makes the fuzz ones different ?(if at all?)
i must say, my ebay one gives a much improved light, and better pattern
digger06
Post by digger06 » Fri Nov 11, 2011 3:12 pm
Newtsalad wrote:I absolutely do not recommend the LED rear bulb, if you value your life. IMHO, they aren't up to the job. That's not just the ones Fuzz sells, I've yet to see ANY one that's 1/3 as bright as a normal bulb. Just my opinion.
i tried a few, i ended up with one that looks like the others, but its white light and was an unbranded cheapo, funnily enough its actually ok,
