Does anyone have a front brake lever+ a clutch lever for a 93 c 90 that they could sell me please.
Thanks for rummaging any way.
Brake & Clutch levers
- Rides:: Suzuki GSXR 750
- Rides:: 1966 S90 1998 royal enfield 350
Re: Brake & Clutch levers
Got a clutch lever measures 5" you can have for nowt next time your passing this way (poets estate)
Pit bike clutch levers are good ,and you just need to extend the left bar by 20mm to fit one.
Not something I've done nor intend to do, but just something I've wondered ..
If you fit a clutch lever on the original C90 left bar, do you have to extend it? Could you not cut 20mm off a grip end, fit a bar end and make do with a shorter grip? Or even cut down a wheelbarow type grip, and not even add a bar end?
Mine has been extended for years with no problems .
I think that should be ok as it’s not going onto standard bars
Thanks for the info.
