After a few parts/numbers...
The bolt circled.. but a short one that doesn’t stick out.. should I choose not to fit a front rack.
An indicator switch.
The rubber seal that goes around the clock.. seems to have become loose or stretched.
Also is anyone able to identify this bike on David Silvers/CMS spares website?
Thanks
Few bits wanted for 1984 C70
- Rides:: Triumph Street Triple
Re: Few bits wanted for 1984 C70
The bolt is just an M8 bolt ,use a bit of M8 studding and a chrome caped nut from Toolstation .
Plus lots of rubber trim available on eBay. as for the switch may be a new set ?
Good idea..
- Rides:: 1960 Lambretta TV175, 2006 MD90 & 1978 CG125.
You may be able to take the switch to bits & repair it possibly.
I believe the switch is working, it’s just missing the control knob thing.. looks like I can get one new from CMS for £7.50 but postage is €15
Don't forget the Vat both ends so that's two lots of VatPlus customers and handling ::: make one out of a bit of plastic...
Getting ripped off again in this country...and new that lot want our Jabs:::
