DAX / CHALY
if you misplace the nuts that hold your wheels to your hubs you are going to struggle getting replacements , unlike conventional 8mm nuts those have a 14mm spanner head , and sit in the recessed section of your hub , normal 13mm headed ones will fut , but they can turn and chew up your hub
shires bikes sell sets of 4 in galvanised at £5 + postage + vat , this is £15.80 delivered (uk) for 8
oo racing sell a bolt kit , 4 x stainless bolts 20mm long (to short!!!) flat and spring washers , at £5 per wheel , so again that is almost £14 delivered for 8 bolts
what I have here , is correct 14mm head STAINLESS steel nuts and 8mm socket capscrews and flat/spring wahers on STAINLESS steel
comes as a set of 8 (one full bike) and delivered to your door UK ONLY for £14
sorry can only do UK only at this point
