Honda c70 6 volt turn signal relay.
fat albert
Rides:: Honda c70
Post by fat albert » Tue Jul 30, 2019 4:32 pm
Hi I’m new to the club & have just bought a 1974 Honda c70 which I’m very pleased with.The indicators on both sides work but do not flash looking at the wiring diagram it shows a winner relay in the system I have looked everywhere on the bike for it & cannot find it please can anyone help.
steveST100
Re: Honda c70 6 volt turn signal relay.
Post by steveST100 » Tue Jul 30, 2019 5:47 pm
Hi It will or should be under the right hand side cover.
fat albert
Rides:: Honda c70
Post by fat albert » Wed Jul 31, 2019 7:36 am
Thank you SteveSt100 I have looked in the area you suggested and it’s not there I have had the leg fairing off and looked to no avail is it possible c70 models did not have a winker relay.
Post by bikerbaker » Wed Jul 31, 2019 8:47 am
If you look up your bike on CSMNL website there will be an exploded diagram which should show where it is or should be fitted.
In my (limited - and with a 12v) experience the flasher relay is unable to cope with high wattage bulbs and they don't flash if you put car indicator bulbs in - they are same size and contacts but 21W instead of 11W - I think. Maybe a similar fault?
fat albert
Rides:: Honda c70
Post by fat albert » Wed Jul 31, 2019 10:20 am
Thank you Bikerbaker have looked at site & have now located the winker relay.All the best Steve
