Innova problem.
- Rides:: anf 125 +sh300i
Innova problem.
I'm getting a clicking noise from the rear of my Innova when pushing with engine off. I have looked for something obvious--chain tension/hub bearing, but all seems to be in order. Any one else had this?
Re: Innova problem.
Check the chain case and also loose/broken spokes.
- Vk/Leeds
- Rides:: Suzuki uh200
Re: Innova problem.
Could be Sprocket carrier bearing , take the top chain case off to check , can not be seen with it on ! ! that what is was on mine but all seemed well with case fitted ! !
Cheers Vk. .
Cheers Vk. .
