Honda Cub Parts For Sale, Engine and Bodywork!!!
- Rides:: C90!!!!
For Sale
Numerous Honda Cub 50 / 70 / 90 parts
Forks, mudguards, swing-arm, engine parts, wheels, and many more.
Just phone to see if I have what you need.
Tel: 01522 887103
Tel: 01522 887103
- Rides:: C90!!!!
Re: Honda Cub Parts For Sale, Engine and Bodywork!!!
BUMP, anyone?????
I need some bits off of a c90zz, clutch, kickstart etc. How about a red front mudguard for a 50, rounded type? How about a rear spindle assembly for a 50? Have you any C100 bits? Cheers!
Do you have a cylinder head with ball bearing camshaft in good condition, for a 12volt Cub 90 engine please?
- Rides:: C90!!!!
Will have a look for the bits for you tommorow, not sure on the c100 stuff though
- Rides:: c90
do you have an older c70 big valve head?
thanks
thanks
- Rides:: Cub90, CG125, GS500, Bimota YB10.
I'm could do with a cub c90 head, the inspection covers on mine are seized, I don't have a valve spring compressor, and it's burning a shedload of oil! A set of rings or a new piston kit and a top end gasket set too. I'm assuming the rings are shot, although the bore is about perfect! Got any advice?
- Rides:: C90!!!!
Will probably have a head, what year is your 90?
Rings are probably you problem cncerning the oil
Advice? Yeah.Rico wrote:I'm could do with a cub c90 head, the inspection covers on mine are seized, I don't have a valve spring compressor, and it's burning a shedload of oil! A set of rings or a new piston kit and a top end gasket set too. I'm assuming the rings are shot, although the bore is about perfect! Got any advice?
The tappet covers are cheap enough to replace. If they won't budge or the nut's are round off, put a cold chisel on the outer edge of them and give them a wallop. Remember, if they don't move, don't force them, GET A BIGGER HAMMER!
