Honda SuperCub C90G and T spares needed gone
George
Rides:: 2015 NBC110XD Cross Cub; 2000 C90T Super Cub; 1998 C90CWV Super Cub, '13 KTM 990
Post by George » Mon Sep 10, 2018 8:46 am
Hello again, I have found some more bits that need gone, prices will be symbolic and negotiable as I need them out of the way. Sold my daily C90s and I don't need these anymore:
Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image
Some bits have sold on the facebook page (big mistake in advertising there...) and these are:
- the 6V Rickman fairing
- Lifan stator + rotor
- front rim with spokes (left with a rear rim with spokes)
- both grab handles
What's left is:
- Almost complete seat (hinge assembly is incomplete, one tear on the side)
- 4 x shoe springs OEM new
- Pl, Silencer - 50385-GB4-000 - used part
- Upper handlebar cowl in used condition with one of the fixings damaged but still have the broken piece so could be glued?
- 2 x exhausts, one from a C90T, the other from a C50 Little Cub (50 won't fit a 90 without some mods)
- OEM new side stand bolt + nut + probably pattern spring.
- Pattern complete front wheel C90G type.
- 3 x bolt + nylock nuts + 2 x spacers for the Rickman rear carrier (the one with the side bag support) these fixings go on the indicator stem fixing location.
- 1 x JT front sprocket new 16T
- Some o-rings and 2 x valve stem seals for the C90G type engine (1986 - 1994?) + 2 gudgeon pin clips.
- Both caps for a C90MT E-Start LH engine cover. The one for the crank nut and the other one for the inspection (checking the flywheel markings for the T F marks) These are OEM new.
- 2 x? copper washers for the head stud top nut seal for the oil feed. New OEM
- 2 x valve stem seals for the C90T (1996-2002) New OEM
- 4 x rear shocks in Shuttle Blue.
- 1 x engine guard (this was received as a gift from Diesel Dave, so would accept just the postage fees for it... never fitted it so not sure how it fits).
- 4 x horns. One is pattern and works, not sure about the other 3. 2 of them might need tuning.
- C90G Square spaced indicators Rickman Faring + fixings. No clear screen with this one. Can be bought new. This one was never fitted so as new.
- Rear rim with spokes, cush drive rubbers
- 2 x mirror mounts (original risers) + 2 x LH threaded nuts + the 2 x rubber protectors that come over the nut and risers. These are all new OEM. So everything for the mirrors without the actual mirrors. :lol:
- 3 x ring sets, 3 x gudgeon pins, 3 x 2 gudgeon pin clips all new (pattern)
- 1 x ring set Original OEM, a complete lower dirtshield fixing set (long screw + spacer + washer all OEM new but not in their original wrappings), overflow or breather hose for the carb... not sure which one... probably breather. 1 magnetic sump plug and washer, 2 x in line fuel filters, 1 x set of cush drive rubbers, some front forks mounts, etc.
- 1 x brake shoes OEM new
- 1 x throttle cable used.
Feel free to ask anything. I'll take offers for all of these.
Thank you.
George M.
ally
Rides:: dr750, mz skorpion traveller, v90, v75a, c90-g, innova fi, fj1200, CG125ES
Re: Honda SuperCub C90G and T spares needed gone
Post by ally » Mon Sep 10, 2018 2:24 pm
pm sent
Billbott
Rides:: 1965 Honda C100 1981 Yamaha RD350LC 1995 Suzuki DR350 2000 Honda C90 2017 BMW S1
Post by Billbott » Mon Sep 10, 2018 2:44 pm
Messaged you 8-)
George
Post by George » Tue Sep 11, 2018 8:16 am
Replied to all. :D
George
Post by George » Sun Sep 23, 2018 7:25 pm
I have found these as well. Front spindle + spacer and nut and rear C90G wheel hub. Drum has surface rust and should clean properly:
Image Image
I'll try to redo the list as some parts are sold now. Feel free to ask me for availability nevertheless. :)
Thank you.
George
Post by George » Tue Oct 16, 2018 1:57 pm
This is all it's left...:
Image Image
- 1 x ring set Original OEM oversize
- Rear hub.
- Axle bolt, spacer and nut.
All for £15 posted without the two exhausts. The exhausts will be £10 + postage.
Thank you.
valentino
Rides:: honda c90mg honda c90p
Post by valentino » Tue Oct 16, 2018 6:03 pm
Hi George .can I have the odds for £15 posted please , pm sent.
Croz
Rides:: Honda 90
Post by Croz » Tue Oct 16, 2018 11:54 pm
Wondering if you have the following for sale (I have been left really stuck thanks to a powder coater losing these parts)
- front brake arm and cam shaft and Rear brake arm shaft Honda (To fit a 1984 bike)
- Pl, Silencer.
If you have the above please let me know thanks !
George
Post by George » Wed Oct 17, 2018 1:17 pm
I will send these to you Valentino. I will be away from today till Sunday. Will be back on Monday and I can post the parcel then if it's alright with you.
- Pl, Silencer.
Hello Croz,
If Valentino agrees to let go of the PI. Silencer, I could send it to you.
This is how mine looks like:
It comes off of a C90T 2000MY bike. No way near a powder coated finish, but in good usable condition. You might need to paint it. I replaced it with a new genuine Honda part from CMSNL... was the last one in stock and it is discontinued.
The cam shafts and levers are still available with your local Honda Dealer. I will refurb my spare brake plates... I could give you my ones, but it will take some time for me to strip them. Are you in a hurry?
Croz
Rides:: Honda 90
Post by Croz » Wed Oct 17, 2018 3:23 pm
Hi George,
Thanks for the quick reply. I am building a custom cub using a kepspeed frame as my original had literally rusted to nothing. You can imagine what the PI. Silencer looks like lol !.
I don't think I am in a rush still have plenty to do to the bike. I sourced new arms front and back but it came to £29 all in (which is frustrating as mine were fine but the powder coater lost them :( )
As you can imagine with the custom build my cost is spiralling a bit out of control lol so I am trying to avoid just buying everything new.
I will be phoning at the end of the week to see if they magically appeared (they have been lost for a few weeks now so I have lost hope).
Thanks George !
