Auto c50 engine- £30 c90zz engine- £30 and other zz bits
- Rides:: C90p
Right, i have a c50 lac engine out of a 1988 (E) bike, it ran fine when it was replaced with a cub 90 egnine, i might even still have an inlet and carb to go with it, the only thing i can think wrong with it is the kickstart was welded on as the splines went. Also, i have a c90zz, it has quite a few bits missing and the frame is very poor, yet somehow it still managed to survive years of abuse as a field bike, it is a 1979 (V) and was blue once!! It has a speedo and i think a front light, no wheels etc, all the frame parts are present but quite rusty. The engine did run but i would imagine it would need the points setting and the battery wont be good anymore, also the carb is missing i believe. If anyone wants anything (or the rest of the bike) then let me know.
I have an idea on prices i would take but not too sure what everything is worth, let me know if there is anything you require and i will let you know. I will get pics up later.
Also i am near southampton.
- Rides:: Yamaha Sr 125
Re: Auto c50 engine- £30 c90zz engine- £30 and other zz bits
Hmm. Now do you have the gearbox sprocket cover for the 90 engine? Also a seat for the 90?
- Rides:: C90p
I might have a sprocket cover somewhere, I'll have to look. I have a seat, it's one with the white bottom half and would need a good clean?? Any use?? I'll get a picture tomorrow!!
- Rides:: c90s
I need a zz engine I could do with a price would u be able 2 post 2 derby?
Yes please .Gustheclunk wrote:I might have a sprocket cover somewhere, I'll have to look. I have a seat, it's one with the white bottom half and would need a good clean?? Any use?? I'll get a picture tomorrow!!
- Rides:: C90p
It's not in amazing condition but it should clean up ok, would be good unless you have an immaculate c90, anyways here is a picture
I have the engine, it hasn't been started in a while and would need the points replacing I imagine, it would also benefit from a good service and maybe a look at the timing. You have a carb to go on it??thechickenchaser wrote:I need a zz engine I could do with a price would u be able 2 post 2 derby?
How much were you thinking for the seat bud? Do you have a sprocket cover?
- Rides:: C90p
Say £15 plus postage for the seat?? If I have a sprocket cover I'll have to find it as it will be in a mates shed!!
- Rides:: c90s
Yep I Have a carb for it just need an engine swap! But wouls need it posting?
- Rides:: C90p
I'll have to get a quote on postage, derby is in Yorkshire I believe??
