1976 Honda XR75 £2500 & 1982 Honda Z50R £2000
RE-OPENED! :)
Russ90
Rides:: Honda C70
Post by Russ90 » Sat Oct 09, 2021 11:03 pm
1976 Honda XR75 & 1982 Honda Z50R
Sold as a pair or seperately
1976 Honda XR75
Purchased July 2020 and has been mostly restored since
Tank resprayed with new decals, frame powercoated, all other parts repainted, all hardware re-zinc coated or new genuine Honda items purchased, new seat cover, plus many other new parts. The engine has been part rebuilt, a good second hand replacement top end was fitted along with honing the barrel and new genuine piston rings, the engine runs pretty well but wants a bit of fine tuning. Some parts haven't been replaced such as the wheels and tyres (original and perished) and a few others bits as the condition isnt too bad but for a 100% restoration they would likely be replaced. It needs a rear mudgaurd and side panel to finish off. An easy project bike to finish off as the hard work has been completed.
1982 Honda Z50R
Unrestored condition with geuine 'patina' but in full running and working order. Has been modified for adult/off road use and had the following carried out:
Carlisle Snow Hog Mud & snow tyres
Modified XR75 swing arm
Longer 325mm rear shocks
70cc pitbike top end
Custom Straight through exhaust
20mm Carb and foam filter
High flow oil pump
Sump guard
All modifications are completely reversable bolt on parts, this bike can be put back to factory spec, all of the original parts are included with the bike.
image uploader
I'm looking for £2500 for the XR75 and £2000 for the Z50R but could do a deal for the pair.
Viewing is welcome. The bikes are located near Ledbury, Herefordshire.
