Honda c125 super cub Sold
RE-OPENED! :)
Dogsbody
Rides:: Greeves Silverstone(2) Oulton (1), Burgman 400, C125 And CT125,, Honda 400/4
Re: Honda c125 super cub Sold
Post by Dogsbody » Tue Feb 02, 2021 6:34 am
JohnS, fitting an external battery charging lead is imperative. If the battery goes flat you need to remove the panel over it but to access it you need to lift the seat but as the release is electrical you can’t as the battery is flat :shock: Dogsbody
JohnS
Rides:: .2019 Honda C125
Post by JohnS » Tue Feb 02, 2021 10:51 am
Thanks for that Dogsbody.Honda slipped up there.
Dogsbody
Post by Dogsbody » Tue Feb 02, 2021 11:00 am
Sorry, should have said to access the toolkit that is behind the side panel the release is under the seat. If you are at home you would have tools anyway to undo the panel. Better to have the charge lead outside anyway. Any info you need I bought a workshop manual from the States.
Seventyheadbarrel
Rides:: C125 super cub / r9t racer
Post by Seventyheadbarrel » Tue Feb 02, 2021 1:23 pm
Great advice met a young lady that suffered this issue and of course invariably your steering lock is on too.
JohnS
Post by JohnS » Tue Feb 02, 2021 3:59 pm
That’s great Dogsbody.Would you mind having a look how the rear light comes off.I only had a quick look and can’t see how it will come off
Dogsbody
Post by Dogsbody » Tue Feb 02, 2021 8:25 pm
Hope your sat down John. :lol:
First remove rear fender, that is
two bolts at side, two bolts at top, two trim clips then diconnect the sub harness connector.
then disconnect light connector, two nuts, reflector, twoscrews and light cover, two screws and licence light unit.
that is for american model so you are the guinea pig. Good luck
JohnS
Post by JohnS » Tue Feb 02, 2021 9:29 pm
Thanks a lot Dogsbody.Good grief.I thought it might be complicated.I’m trying to fit a high level brake light.I might try looking for an electrical supply from somewhere else,the brake switch possibly.
Post by wightegi » Tue Feb 02, 2021 11:24 pm
I have a high level brake light ,a strip LED from Wish very bright and stuck on to the rack on my Xevo.
17cm cob led cost £2 for 2 .
JOHNBOY
Rides:: HONDA SUZUKI
Post by JOHNBOY » Wed Feb 03, 2021 9:52 am
any pics please
JohnS
Post by JohnS » Wed Feb 03, 2021 11:19 am
I have fitted two,one to my C90 and one to my scooter.Sorry no pictures though.
But getting at the wiring on this C125 looks a much bigger job.
