85cc monkey bike upgrade to 110cc? Will it work
Monkeysteve
Rides:: Ktm 300
Post by Monkeysteve » Fri Jan 29, 2021 11:55 pm
Any advice appreciated
Bike is a skyteam st90 monkey bike 85cc. Similar if not same as c90 I’ve had in the past?
Don’t want to buy parts and not fit
cozi70
Rides:: Z50,cf70,msx and an auld german 1200gs
Re: 85cc monkey bike upgrade to 110cc? Will it work
Post by cozi70 » Sat Jan 30, 2021 1:46 pm
Hello Steve and welcome aboard.
With the 107cc kit fitting on the 85cc Honda cub 12v engine there is a strong chance it will work.
Early 12v cub engines need the casings opened up manually,but later ones are already wider to accept the 107 barrels bigger skirt,so I'll interested to know how yours appear.
Have you looked at the kit from petrolscooter?
Colin J
Monkeysteve
Rides:: Ktm 300
Post by Monkeysteve » Sat Jan 30, 2021 1:54 pm
Thanks for the reply
Yes I’ve seen the kit from petrolscooter on eBay and it’s cheap but unsure how good it will be? Have you had any experience with these kits reliability wise. I would like to know if it will fit before disassemble and buying parts ideally? Thanks again
cozi70
Post by cozi70 » Sat Jan 30, 2021 2:51 pm
Yes,I have already done a 1988 motor,but only covered around 500 miles on it,and I'm about to do a 1996 engine, both using those kits.
Monkeysteve
Rides:: Ktm 300
Post by Monkeysteve » Sat Jan 30, 2021 7:57 pm
Just taken mine apart and measurements seem right. Do you upgrade the intake or jets? If to what sizes. Thanks
cozi70
Post by cozi70 » Sat Jan 30, 2021 8:25 pm
I ran the standard issue 110/125cc pit bike 22mm carb and it was fine,but read others retained their standard cub carbs,19mm iirc,and upped the main jet slightly.
Monkeysteve
Rides:: Ktm 300
Post by Monkeysteve » Sat Jan 30, 2021 9:09 pm
Any idea what size jet to go to?
cozi70
Post by cozi70 » Sun Jan 31, 2021 12:05 am
There is guide in this forum that discusses this conversion, think they explain the jet sizes.
Monkeysteve
Rides:: Ktm 300
Post by Monkeysteve » Sun Jan 31, 2021 11:48 am
Did it you have to modify the crankcase- make wider for barrel skirt? Measurements of the skirt seem it will just fit but think it will be close
cozi70
Post by cozi70 » Sun Jan 31, 2021 1:21 pm
I've only experience with bigger Chinese engines,but the later Honda c90 engine I'm about to do doesn't need the around 2mm excess removed to fit the 107 kit,but the earlier honda did.
