85cc monkey bike upgrade to 110cc? Will it work
Monkeysteve
Rides:: Ktm 300
Re: 85cc monkey bike upgrade to 110cc? Will it work
Post by Monkeysteve » Tue Feb 02, 2021 9:59 pm
I’ve done the rebuild today, starts first kick but won’t Rev up past 4000rpm? Runs fine up to that point and just sits there and bogs on full throttle then will come back to tick over ok? Do you think jetting or something else? Doesn’t seem to be leaking anywhere and everything torqued down properly. Any advice on jetting? Thanks again
Monkeysteve
Rides:: Ktm 300
Post by Monkeysteve » Wed Feb 03, 2021 7:32 pm
Fixed now. Valves needed adjustment. Any advice on correct jetting?
Post by wightegi » Fri Feb 05, 2021 9:48 am
The larger capacity will suck more so smaller jets maybe in order. Diesel Dave has a section on jetting LIfans which would be worth reading .
viewtopic.php?f=20&t=30162&p=278481&hil ... ng#p278481
or put Lifan 110m jetting in the search box.
Barnsey
Rides:: Honda C50 BMW R100
Post by Barnsey » Sun Aug 08, 2021 12:59 pm
I was recently advised to put a #83 main jet in my Lifan 110 powered cub replacing the #75 which the carb came with. I will be testing this out this week hopefully, showers dependent.
