Replacing Gaskets - How To?
Posted: Tue Oct 20, 2020 9:44 am
by willmc
Hello All,
I am buying the complete gasket set from shirebikes to replace all of mine on the ST70, from pulling apart the engine I can see thr gaskets are almost stuck down, am I right? And if so what do you use to stick the gaskets down?
Sorry probably an simple question but I am new to this and learning as I go.
Thanks for the help all.
Re: Replacing Gaskets - How To?
Posted: Tue Oct 20, 2020 3:34 pm
They are not stuck down , a light smear of grease my keep them in place as you assemble the engine .
Posted: Tue Oct 20, 2020 7:37 pm
by slowboy
What wightegi said. Avoid using gasket sealer, it’ll end up in all the wrong places inside the motor. It has a nasty habit of blocking small oilways in time.
Posted: Tue Oct 20, 2020 8:02 pm
by bikerbaker
slowboy wrote: ↑Tue Oct 20, 2020 7:37 pm
Brought back memories of a mis spent youth when I garmed everything in sight with Red Hermetite with my fingers.
Posted: Wed Oct 21, 2020 12:08 pm
by willmc
This is great thanks guys, another stupid question is there a particular grease you guys like to use when working on your Honda Monkey Bikes, anything anyone can recommend? Let me know thank you!!
Posted: Wed Oct 21, 2020 1:50 pm
by slowboy
willmc wrote: ↑Wed Oct 21, 2020 12:08 pm
Ordinary LM grease will be fine. Only need a very small smear. I put it on the outside face on the clutch and alternator covers, they come off so much easier later without ripping the gasket.
Posted: Wed Oct 21, 2020 4:24 pm
by willmc
So helpful thanks for this, I apologise I am new and learning as I go
Posted: Thu Oct 22, 2020 7:09 am
by Alan CF
You can buy gasket spray to help remove the old gaskets.
It's a bit hit and mis with that stuff. Depending how hard the paper has got. Peel as much off as you can then try the spray... or use a Stanley blade at correct angle works well.
Posted: Thu Oct 22, 2020 10:27 am
by andyk1k
My own experience is NOT recommended but faced with leaks of oil from Asian imported gaskets 2 total engine strip down's and another session rubbing the mating surface flat l finally cracked and bought sheets of flexoid and a tube of araldite
made the gaskets up then scraping the araldite off to a very fine film put it back together and waited a couple more days to cure,stopped all leaks but l would not recommended this unless your desperate and end of your patience
