12v c90 engine in a honda st50 dax
bobhowe
Rides:: 1987 Honda ST 50 1969 Honda PC 50 ( OHC ) 1972 Puch Max N
Post by bobhowe » Wed Jul 15, 2020 9:29 pm
Hi just put a 12v c90 engine in my 12v Honda ST 50 Dax i am the standard c90 carb & manifold what air filter should i use as the carb faces forward tried to turn it round to face backward & use the st50 air box & it does not line up as the engine stroke is longer & the manifold is slightly higher any ideas would be greatful :D
slowboy
Rides:: Honda C90e 1986, Honda Super Cub 125, Yamaha FZS600 Fazer
Re: 12v c90 engine in a honda st50 dax
Post by slowboy » Sat Jul 25, 2020 5:51 am
I'd have a look at some of the pit bike options to see whether anything they had might fit. What about the manifold of the 50 engine could that be adapted? Other than that, why not get something made bespoke to fit. A flange and a piece of steel tube with the right diameter bent to the right shape and welded together would be fine.
andyk1k
Rides:: S90 now on swaps in the marketplace
Post by andyk1k » Sat Jul 25, 2020 6:28 am
Local fabrication works will cut it and shut it using alloy tig welding,shouldn't cost that much for ten minutes work.
