Lifan 110 engine
c90bobber
Rides:: fireblade
Lifan 110 engine
Post by c90bobber » Mon Feb 24, 2020 11:46 pm
Anyone used a Lifan 110 for the plop enduro ?
Just wondered how reliable they have proved to be......
culfy
Re: Lifan 110 engine
Post by culfy » Tue Feb 25, 2020 1:51 pm
Out of a hundred bikes there is always 20 to 30 with Lifan’s in, don’t buy a second hand one buy new, change the oil and run in before the race , they seem to last ok good luck.
c90bobber
Rides:: fireblade
Post by c90bobber » Tue Feb 25, 2020 11:04 pm
Thank you so much :)
Mine was new in 2018 and has now done about 1000 miles and I ran it in quite carefully.
I've been using the bike fairly regularly on the road and have converted to "race trim" now so I will just have to see how it goes.
culfy
Post by culfy » Wed Feb 26, 2020 8:49 am
It will be fine just put fresh oil in before the race and don’t forget to wire your sump plug and filler cap .
garth
Rides:: C50LAC / C90 plop / C90 / Versys / WK450 RX
Post by garth » Thu Feb 27, 2020 1:52 pm
I did Cadwell on a brand new 110 lifan. Took it out the box, changed the oil, then held it flat out with zero running in whatsoever, all day.
It was fine, it didn't even use any measurable quantity of oil.
Think I got the fifth or so fastest lap time out of all the bikes running. Not bad!
c90bobber
Rides:: fireblade
Post by c90bobber » Thu Mar 12, 2020 12:03 am
Wow , very impressed😀
c90bobber
Rides:: fireblade
Post by c90bobber » Sun Mar 15, 2020 9:51 pm
another query Guys......
When I fitted the Lifan 110 I didnt change the jets in the carburettor, I just used the carb that was on the c90 engine. The bike seems to run fine but I wonder if I would get more power/speed if I up the size of the jets.
Any advice much appreciated
Maintenance Stasi
Rides:: 2 x C90,BMW R1200st, BMW R80RT, SH300, Super Cub C125A, Innova
Post by Bogger » Mon Mar 16, 2020 5:20 pm
No you won't.
