I think a 'good' T150 with rayguns would hit 130... Naturally that was a carefully built test bike...But they'd get there. I had those grey faced Smith's clocks on my '71 T100R and they were internally adjustable so could be set up to be absolutely spot on. I worked out the revs/gearing and after checking and adjusting the tachometer which also had a brass adjuster screw in it, set the speedo to be spot on at 70 mph. Top whack on my lightly tuned T100R was 112 and it would lift the front wheel in first when it hit 4800 rpm. ~I don't think my T100R had the conical brake, it was full width with a scoop...that's where my mistake comes from.DRAG90 wrote:American Craig Vetter was responsible for the X-75 styling.
If you believed the wildly inaccurate "Smiths" then 130mph was possible . the truth is more like 110-115 in STD trim.
The Triumph/BSA conical hub was 2LS not 4LS, and was known as the "comical" hub for it,s extremely poor stopping power and was dropped in 72 in favour of a Lockheed disc.
The CCM,s do look and sound the dogs danglies,made from the remains of the BSA comp shop, but were a vastly overstretched C15/B40 and a nightmare to own/race. A big improvement was the Rickman (designed by Weslake) 4V head
I once spoke to an MX guy who had recently gone over to XT500 powered bikes from the B50 . He said a B50 would need a new piston and rebore after two meetings whereas the Yams would go a season without a qualm...Again, i think more to do with lubrication than metallurgy...The XT had a ferociously powerful trochoidal oil pump compared to the BSA's pre war thing.
