yamaha rsx100 headlight
- mark1982
should a rsx100 have the same headlight bulb as my c90 as the one in it at min looks more like a car headlight bulb??
- mark1982
Re: yamaha rsx100 headlight
just noticed should be rxs lol
- Cerberus73
RXS is a 6 Volt bulb... 6 volt bike, mine from memory kinda does look like a car bulb, heres link to them on wemoto.
http://www.wemoto.com/bikes/Yamaha/RXS_ ... Headlight/
- mark1982
hmm i will have to get the bulb out an have look as only looked thru glass it cant be right bulb as the light throw is all wromg it lights up the sides the road and got big dark bit in middle were ment shine amy ideas
- ll81
- Rides:: CBF125 Z250SL
Round headlights need the correct bulb/reflector bulb combo. If it's wrong it will light up the side of the road or just point upwards. My C70 had a large hole in the middle of the beam on dip with a reflector type bulb in, a dual offset element bulb sorted the problem out.
- mark1982
so a bulb like my c90 would sort it then will have pop down bike shop
- mark1982
my mate just said not to rag it around everywere but to ride it in the power band this is my first geared bike on roadwell as well as my c90 and first 2 stroke owned were is the power band on them bikes its completly stamdard bike??
- Cerberus73
mark, i can't tell you cos mines is a bit of a beast, been ported, flowed, and bored out to 135cc, and carbon power reeds, with a custom made expansion pipe, the bike is producing about 22+hp (prob near 25, not dyno'ed it yet), and the chassis has been pared back to the basics, or will be when complete. if i mind right its around 4000-7000 rpm on the bog standard bike I've only ever ridden a standard one once. and even it had a expansion pipe (allspeed) and fibre reeds fitted. they can be surprisingly quick little bikes and a lot of room for improvement over the standard bhp can be had. look at RX 135, and 115 pistons, barrels etc, also its possible to fit a DT175 air-cooled head on if con rod and piston are changed, the bottom end is tough enough to take it. the RX 115 and 135 are still made and sold in SE asia and india. i got my motor breathed on but Stan Stephens but it seems from what io read in motorcycle mechanics recently, he is only doing real high end stuff now, as he is knocking on a bit and wants a lower workload. but racoon do decent work. but do not ignore the YEIS boost, it gives the RXS a smoother power spread than a lot of 2 strokers of the day, so the torque is layed down a bit more like a 4 stroke, hence 3000 rpm window of opportunity for the power band. but if you do decide to rebore etc, make sure you source a boost bootle from the right model, i.e., if ya use a 135 piston get a boost bootle off a RX135, same for 115 as the boost bottle is matched to the capacity of the bike. fitting a bigger boost bottle won't give you any more power. so its no cheap bolt on power up.
http://www.raccoon2strokerebuilds.co.uk/
- mark1982
thanks and thanks for the link and info i will look into that further when i get more used to riding the bike and gears
- mark1982
have found the problem its the rite bulb but the metal ring around the bulb has come away from the bulb causing it to make bulb shine in wrong place
