Welding help required
Re: Welding help required
You will get a new crank from that site with the e in it's name. for about one and four pence, will have come from China but they are not all bad.
- Rides:: honda c90mg honda c90p
blimey i can,t strip the engine i dont have the skill, its scrap if i cannot weld it But its a pity cos its a strong engine The damage done when some bastards tried to pinch it and maybe did not pull the brake on when they tried to start it
It would be very simple to get another motor from E.bay and swap them...only undoing nuts bolts screws, ripping a few bits of plastic from the frame..
Stick it in a van and send it here i will do it, send the new/S/H crank with it or motor ..no cost some thing to do: After lock up if in person:
Lyn.
Lyn.
I THANKYOU VERY MUCH FOR YOUR HELP, I WILL SEE IF I CAN GET SOMETHING SORTED AND PERHAPS TAKE YOU UP ON YOUR KIND OFFER BUT NOT FOR NOTHING !!!
Not a lot of engines out there now , but there is a crank with con rod for £28 on eBay search Honda SH50 in parts .
Retired i do stuff to keep me sane not for money:::will make a change from making parts for old obsolete tractors for the local farmers
Thanks i got the crank as mentioned ,so i will try and remove the lump ! THANKS AGAIN
Perhaps kayz1 would like to visit the fergie museum on the Isle of Wight .they sold the FF though .
