yam townmates
- Rides:: '91 c90,2000 an400
yam townmates
can shaft drives (ratios?) on the above be changed like changing sprocket sizes on c90s or are you stuck with what it leaves the factory with?
Re: yam townmates
Stuck with what you've got pal.
Re: yam townmates
As above not a lot you can do wider rear tyre might up the ratio ,but the T80 should get to 60 with ease .
Re: yam townmates
thanks for that, I thought that would be the case just wasn't sure......
