Yeah seamed happy around 50mph.Earnest Thrasher wrote: ↑Sun May 30, 2021 8:54 pmWhat sort of cruising speed was it comfortable at. Now that mine is run in it will pull faster in 4th than 5th unless you've got a decent tailwind or downhill. It seems comfortable at an indicated 50 mph in top.
From what I've read the new 5th gear is almost the same ratio as the old 4th (top) gear,which we always felt over geared the bike, so for years we ran +1 rear sprockets which we felt made top more usable as it increased the rpm's,and last year we fitted minus 1 front sprockets which again changed the characteristics and we felt increased acceleration but robbed a little top speed.
I did intend to fit a TB high lift cam and have the ecu reflashed to increase the fueling but recently purchased a modified monkey.
