not honda but bsa
barker
Re: not honda but bsa
Post by barker » Thu Jan 30, 2020 5:14 pm
new relief valve \arrived , so fitted it filled tank with oil after some issues we managed to get the a10 to run one minute later oil dripping out of engine ,took oil tank cap off no oil returning its had new oil pipes fitted so none of them will be blocked
next step the pump
slowboy
Rides:: Honda C90e 1986, Honda Super Cub 125, Honda CRF250 rally 2017
Post by slowboy » Thu Feb 06, 2020 11:16 pm
next step the pump
And if that doesn't work, there's always the "fag in the tank" solution. It saves a sore throat from swearing at it loudly which as an intermediate phase I found was ineffective and wasted valuble time
:lol: :lol: :lol:
barker
Post by barker » Fri Feb 07, 2020 12:02 am
well phoned the firm in wales who reconditioned the engine after a brief chat about the problem they told us to check the sump plate on the right way around that was ok then the pick up pipe check that the ball bearing moved freely ours did nt hence the reason the the oil was not returning to the tank
sorted out the ball-bearing filled the tank with oil started the bike ran it for five minutes oil returning to tank and only the normal oil leaks from the rocker covers
so all sorted
