Innova dash lights
- Rides:: Cub90
Innova dash lights
Hi
Can anyone give me any info regards neutral and gear selection lights not working? The rest of the dash is light up just not the gear selected
Is it just a bulb or not quite so simple?
- Rides:: Cub90
Innova dash lights
Hi
Can anyone help me with regards to gear selection lights not working? The rest of the dash is light up just not the gears,is it a simple fix or more complicate?
- Rides:: PCX 125, Vision 110
Re: Innova dash lights
the gear indicator switch is located in front of the front sprocket, gets covered in chain gunge, probably needs a good clean and a new spring while your at it.
- Rides:: Cub90
Great thanks,so if it's just the switch no gears or neutral would be light up?
The parts are very cheap from a Honda dealer (<£5), very simple to do.
- Rides:: Anf125i
@GPP 22, cleaning before bying new makes sense https://www.fowlersparts.co.uk/parts/view/35750KPH900
The parts you need are
PFKL 534554 CAP CHANGE SWITCH CONTACT £2.74
PFKL534572 SPRING CHANGE SWITCH CON £ 0.17
Info from the E16 fiche ANF125/7
They fit inside the gearchange drum, replaceable when you undo the switch. The switch contacts should be ok, so don't order one.
So total cost is £2.91 and simple to do.
- Rides:: Anf125i
Honda part no's in reddmw1950 wrote: ↑Wed Feb 20, 2019 11:50 amThe parts you need are
PFKL 534554 CAP CHANGE SWITCH CONTACT £2.74 35751KPH900
PFKL534572 SPRING CHANGE SWITCH CON £ 0.17 35752KPH900
