Townmate 80
ruffstuff
Rides:: Aprilia Pegaso 650, Vespa PX125
Townmate 80
Post by ruffstuff » Sat Dec 29, 2018 2:30 am
Hi, after lurking for years I finally got a placcy.
I went with the townmate as it came up cheap and I like shaft drive simplicity.
So the drive to get it took me 12 hours thanks to our fantastic motorway network :?
I've no idea how to do pics off a phone.
Anyone any tips on t80s ?
ruffstuff
Re: Townmate 80
Post by ruffstuff » Sat Dec 29, 2018 2:37 am
ally
Rides:: forza 300 v90, v75a, c90-g, fj1200, CG125ES, cb250, ybr250
Re: Townmate 80
Post by ally » Sat Dec 29, 2018 9:43 am
I'd like to add one to the stable, have a v75s and a v90 to sort first
barker
Re: Townmate 80
Post by barker » Sat Dec 29, 2018 2:07 pm
12 hours were on earth did you go to
Imagegreenshot download
barker
Re: Townmate 80
Post by barker » Sat Dec 29, 2018 3:06 pm
a couple of tips first dont go out if its dark the lights are crap two check the tyre presures weekly for some unknown reason thery loose air even if you fit new tubes ,, and keep the oil topped up , there not fast bikes but will keep up with most cubs on a bimble
ive had mine for ten years done 24000 miles now would like better lights but would,nt all of us
dmw1950
Rides:: Enfield Hunter 350/CB125F/Silverwing 600/Vespa250GTS
Re: Townmate 80
Post by dmw1950 » Sat Dec 29, 2018 3:59 pm
Take off the rear light, clean the earth contact at the back if you have a poor brake light. .
Remove the swing arm spindle and swing arm, left hand side engine case, check the ignition pick up for corrosion,
Open up the shaft hub, clean and refill with Castrol grease, its a liquid type.
Grease the splines of the prop both ends, it makes a great difference to the gear change mine would jump out sometimes before I did it.
You can get a Lucas 6 volt gel battery these days for £9 that's a good fit.
hopefully the cam chain adjuster can be moved in the cylinder head.
A few jobs that need doing, to make them better. Happy Days.
ruffstuff
Re: Townmate 80
Post by ruffstuff » Sat Dec 29, 2018 4:37 pm
Sound advice, I've got oil and ordered the brake bits, job for tmrw.
It was in Bristol, m6/m5 roadworks meant 50 miles in 2nd ☹. Came back through Wales as It was easier.
Re: Townmate 80
Post by bikerbaker » Sat Dec 29, 2018 5:26 pm
Looks great!
Never noticed before how much larger the seat is in comparison with the C90.
ruffstuff
Re: Townmate 80
Post by ruffstuff » Sat Dec 29, 2018 9:21 pm
Any idea of tyre pressures ?
Re: Townmate 80
Post by wightegi » Sat Dec 29, 2018 9:37 pm
Try 40 rear and 30 front ,the same as a 90 .
