Getting the most out of a 125
ChesterC90
Rides:: C90 and Lambretta
Post by ChesterC90 » Fri Oct 06, 2017 8:53 pm
Finished my cub project
125 Lifan: Kepspeed exhaust:
Open mouth filter: 120 rear; standard front: 16^39 sprockets.
Very nippy in all gears, but top speed of 44mph, less than the 90!
Any tips? Engine just run in...
culfy
Re: Getting the most out of a 125
Post by culfy » Fri Oct 06, 2017 9:34 pm
What carb ?
ChesterC90
Post by ChesterC90 » Fri Oct 06, 2017 10:19 pm
Standard 90 , 19mm I think
culfy
Post by culfy » Fri Oct 06, 2017 10:29 pm
That might be the problem , if you go in the search bar and look up what others have done , you will find that most find the standard carb a bit restrictive on the 125 engine , I’ve got a molkt on my Lifan 125 and it goes like stink .
ChesterC90
Post by ChesterC90 » Fri Oct 06, 2017 10:37 pm
Cheers Cuffy.
I've got some 22, 26 and 28 carbs.
What mm' is yours and what sort of top speed are you getting? I'd like 50 +, just for dual carriage way riding,
Maintenance Stasi
Rides:: 2 x C90,BMW R1200st, BMW R80RT, SH300, Super Cub C125A, Innova
Post by Bogger » Sat Oct 07, 2017 7:59 am
Cheers Cuffy.
Best put it back to standard then :lol: :lol: :lol: :lol: :roll:
JohnS
Rides:: .WK GTR300 scooter(copy of SH300)
Post by JohnS » Sat Oct 07, 2017 10:33 am
You say "very nippy in all gears",so your problem could be gearing.I ran an 18 tooth front sprocket on my 110 Lifan which gave it a top speed of 50 to 60 mph depending on wind,with 47 mph in 3rd.18 was the largest that would fit on the 110.Pit Bike Spares sell them,but check they will fit the 125 shaft.
ChesterC90
Post by ChesterC90 » Sun Oct 08, 2017 6:10 pm
Does a tight chain hinder? I admittedly cut mine too short, which is a bit too tight, but with enough play to work.
Tempted to add another link with a clip master link, but concerned about the safety of running 2 master links. Hoping that with the 90's relatively low speeds, it won't matter.
Any thoughts???
Maintenance Stasi
Post by Bogger » Sun Oct 08, 2017 9:30 pm
Yes it does matter. Alter it and see what happens
ChesterC90
Post by ChesterC90 » Thu Oct 12, 2017 9:19 pm
Slackened the chain (new) tried various front sprockets 15 16 17 and it still tops out at 45.
Which is a bit frustrating because I bought the Lifan for 4th gear and to get up to 50+ to stop getting bullied by f@ckin considerate car drivers on the occasional but unavoidable by pass travel.
Only thing I can think is the carb , it's still the standard 19.
Bigger can you add a 4th gear to a c90 engine?
