RIDERS CUB DISCUSSION
steveST100
Re: RIDERS CUB DISCUSSION
Post by steveST100 » Mon Jul 10, 2017 12:08 pm
See this thread i made.
viewtopic.php?f=57&t=28249
You may have to grind the two stubs off the frame to fit the cub bracket if the cub seat doesn't fit with your bracket.
I dont have a riders seat bracket to try,but if you post a photo of your bracket with the seat up should have a better idea if it will fit.
gtd65
Post by gtd65 » Mon Jul 10, 2017 12:26 pm
Looking at your link it makes me think I should be stripping the bike down and applying some undercoat to the bike at some point, before any surface rust sets in!
Either that or a good coating of ACF 50 or suchlike?
steveST100
Post by steveST100 » Mon Jul 10, 2017 12:43 pm
Better now than trying to weld the rust up later.
gtd65
Post by gtd65 » Wed Jul 12, 2017 6:01 am
Have you applied anything to your frame that you would recommend?
I only use it on fair weather days generally (unless I get caught in a shower) and never in the winter so it "should" be good as is really.
steveST100
Post by steveST100 » Wed Jul 12, 2017 12:25 pm
Used zinc oxide paint and seam sealer then painted it.
May put some stonechip stuff under the backend later.
Need to crack on with this one as i want it out of the way to get on with rebuilding two of my own cubs.
Kod
Rides:: CB750KZ,C90C,Kawasaki550GT
Post by Kod » Thu Jul 13, 2017 6:45 am
After having the frame stripped I sealed the seams with Tiger seal and painted the underside with 2 coats of Galvafroid which is a cold galvanising paint. Next was 2 coats of red oxide followed by primer and finished colour which is Traffic Red from Monstercolours in Glasgow.
cornmek1
Rides:: 2011 Riders 110 ( c90 copy ) , Honda H100, Vespa T5 Classic, & 150 Super
Post by cornmek1 » Tue Aug 01, 2017 8:41 am
Yesterday, after I'd reached the max on the adjusters.. I conceded that my original Riders Cub chain-of-cheese
has stretched its last.. lasted ~ 12000 kms
regards
Kevin
gtd65
Post by gtd65 » Tue Aug 01, 2017 8:42 am
That's not too drastic I guess. What will you be replacing it with?
gtd65
Post by gtd65 » Wed Aug 02, 2017 11:12 am
hairygit
Rides:: 1986 C90, 1975 CB750F1, 1982 CB650SCC
Post by hairygit » Wed Aug 02, 2017 4:39 pm
Has anyone ever galvanised (Dipped in molten Zinc) a cub frame? It's very common with Landrover owners as the chassis being steel rots away if not adequately protected, usually from the inside out! Would certainly extend the life of a frame on a Cub.
