RIDERS CUB DISCUSSION
gtd65
Re: RIDERS CUB DISCUSSION
Post by gtd65 » Tue Feb 26, 2019 10:53 am
It's all bog standard, other than an NGK spark plug.
Oh and I replaced the battery last year with one from CPS. (£11.99)
Will probably need to do an oil change in the spring as well.
gtd65
Post by gtd65 » Tue Feb 26, 2019 10:55 am
Could actually do with a slightly more comfortable saddle.
Was wondering if something cheap and cheerful from say a CG125 could be used on the existing seat base? Or just modified to suit. You can get complete units for £32 on eBay etc.
gtd65
Post by gtd65 » Tue Feb 26, 2019 10:57 am
E.g
https://rover.ebay.com/rover/0/0/0?mpre ... 1650922957
cornmek1
Post by cornmek1 » Wed Mar 27, 2019 3:41 pm
Rear light blowing constantly ? A fellow (red) Riders rider gave up on his bike due to this....
I recently had headlamp issues & my local C90 guy said he'd found a poor connection in the headset harness ( somewhere in that ratsnest ) - job done.
Now then.. since thats fixed, the rear light hasnt blown once..
Just saying..
regards
Kev
garth
Rides:: C50LAC / C90 plop / C90 / Versys / WK450 RX
Post by garth » Wed Mar 27, 2019 4:17 pm
The rear mudguard vibrated like an absolute bastard on mine. This resulted in a rear bulb lasting about 5 miles at a time.
To cure this i fitted genuine H engine mounts, which don't stretch like the originals, and replaced the rear light with an LED unit.
No worries after that.
gtd65
Post by gtd65 » Wed Mar 27, 2019 11:59 pm
I've never had any issues with mine so far.
I need to resolve my old GSX-R 750G rear number plate light as it's vibrating and blowing bulbs.
One thing about the Chinese light units, they don't seem to use gaskets at all .. :|
cornmek1
Post by cornmek1 » Fri Apr 19, 2019 10:09 am
Hit a deep pothole... And my re-glued rear light assembly needs re-gluing.. hey ho.
Regards
Kev
gtd65
Post by gtd65 » Wed Apr 24, 2019 4:56 pm
Well I had my worst day out today :lol:
Went on a roughly 75 mile run and all was well until about 2/3 of the way when the bike just cut out, in the middle of nowhere.... :?
Did the usual checks but couldn't see anything obviously wrong.
Then tried starting the bike and away it went...TFFT!!!
10 seconds later, bike cuts out once more.... :o
Up on the centre stand, check the plug cap - and notice that the side stand switch cable is somehow hanging down, tuck it up over the gear changer and away I go... so my next job will be to completely remove the side stand switch - anybody else done this before?
About 10 or 15 miles later I notice that my speedo needle is oscillating side to side and won't indicate above 40 but I know by the sound of the engine and general speed that I'm doing at least 50... Eventually the needle goes back to zero but the odometer is slowly counting... 5 miles or so later it's not moving either. Assumed broken cable to speedo etc.
Get off the bike and see that the rear left indicator is missing....ar$e!!!
Take the bike to the shed and discover that the indicator lens and reflector is lying on the grass so must have fallen off before I even got on the bike! :lol: Refit indicator and reflector...
Discover that the rear light has blown, change the bulb.
Have a look at the speedo cable - different type than I'm familiar with but insert small screwdriver bit into end and use power drill to turn - speedo working fine and presumably there's a problem in the front hub...? Anybody got any experience of the hub drives for the speedo?
Other than that, it was a nice ride out but turned absolutely Baltic on the last half of the ride.
cornmek1
Post by cornmek1 » Thu Apr 25, 2019 9:26 am
Speedo. I bought a new worm gear off ebay when the last one turned to cheese. Easy to fit. Front Indicators popped out, with minimum sideswiping & broke the retaining tabs years ago.. Never played with side stand cut off.... have to resolder the tank gauge connector every 6 months too.. Replace the rear axle with a Honda one at the earliest opportunity too.. Soldier, I was that rider.....
Regards
Kevin
gtd65
Post by gtd65 » Thu Apr 25, 2019 10:32 am
Well, I've removed the front wheel to have a look.
Here's the pics...
https://i.imgur.com/tJCap9Z.jpg
Shoes showing minimal wear
https://i.imgur.com/wWMEWgU.jpg
