guildbass wrote:.Although the Fi system may well be a bit juicy...
I read somewhere on t' net the PGM system is very low current.. Designed to start ok on alternator power only with a completely flat battery.
However, the Innova has a separate centrifugal clutch to it's multiplate. In my opinion this is because the extra torque and higher gearing of the 125cc engine would wear a clutch similar in size to the stock 90's multiplate clutch somewhat prematurely if ridden as an automatic during most manoeuvres, so instead of increasing the Innova's clutch surface area significantly to cope, they gave it a separate clutch to manage it's auto abilities.
I think they changed the design for smoothness of riding rather than (or as well as) a torque issue.. The same double clutch setup is also used on Honda Dream 100, Cub 110, Wave 100/110 etc.
The Innova also apparently has a crankshaft brake, which slows the crank down for gearchanges, but I've never been inside one to see how it works. Dunno if the 100/110 also does this.
The end result is that in fourth gear it'll run right down to almost walking pace and pull smoothly and strongly away. The centrifugal clutch is utterly seamless on operation and you genuinely can't tell when it is working. On the C90, you could feel the clutch lock up if you ran down below 15 mph and accelerated away in top...On the Innova there is no sense at all... It's really nice like that and makes for a very efficient smooth transport solution.
That's about the only thing I
dislike about my Wuyang engine (same clutch setup as the Innova) Where the Cub's clutch would lock at fairly low revs, this slips like a bugger below about 25mph in top. All that wasted energy!
Same under hard acceleration.. The old Cub type clutch would be nicely locked when you release the gear pedal, this one slips into engagement after every upchange like a knackered manual clutch would.
The only downside so far is 100 mpg thrashed flat out
That's interesting. My mate gets 140+ from his - but he does ride it like a nancy boy!
