HI all,
I have just got my self a Cub 90 V reg. 6volt i think. The battery is missing. Its been stood and needs a bit of work. What is the way to go full resto or oily rag wipe over.
But a battery is a must any recomendations?
Thanks Dale.
Newbi
Re: Newbi
Is it a round headlamp with a bolt on external tank? If so it's a 6v. If it's a round headlamp with an internal tank it's a 12v. If it's got a square headlamp its a 12v. Welcome by the way.
- Rides:: Honda C90 XTZ 660 Tenere
Re: Newbi
Hi Bogger
Thanks For the Reply. Its a round headlight. Bolt on Tank. So 6V. I suppose if I thought about it I could have checked the bulbs.
Can I go Gel battety or does it need to be lead acid?
Thanks Again Dale.
Thanks Again Dale.
Re: Newbi
If you are going to fit a new battery have a read of Drag 90`s post on an upgrade, the 6 volt 90 will not run without a good battery so bigger is better.
http://www.c90club.co.uk/viewtopic.php? ... ry+upgrade
