New member C50 (newbie)
garirox
Rides:: C50
Post by garirox » Mon Dec 07, 2020 5:30 am
Hi all, I'm new to the forum and new to owning a Honda C50, the information i have on the bike is limited, even I'm not sure what year it is :) Hopefully some people here may help me understand more about the bike I just purchased :)
Re: New member C50 (newbie)
Post by wightegi » Mon Dec 07, 2020 10:01 am
Hi ,you may find the info here viewtopic.php?f=11&t=1098 , Have you got the number plate if not a member on here can find it from the Vin number .
garirox
Rides:: C50
Post by garirox » Thu Dec 10, 2020 5:18 am
Hi, Its Vietnam model but the Vin is C50E 3050079 Dont know if thus helps or not :)
garirox
Rides:: C50
Post by garirox » Thu Dec 10, 2020 5:57 am
Hope these photo uploads work ok :)
Post by wightegi » Thu Dec 10, 2020 9:33 am
We do not have all the information on all bikes , is it 6 or 12 volt ? the battery will have 3 filler plugs for 6 volt anmd 6 for 12 . The wiring loom may have a label with the date on it under the legshields ,so worth removing them to look .Are you based in Vietnam ,put a rough location in your details .
garirox
Rides:: C50
Post by garirox » Fri Dec 11, 2020 2:36 am
Thanks for the reply, its a 6V , only know as searching for a headlight bulb and thats 6V
Post by wightegi » Fri Dec 11, 2020 9:43 am
OK the enclosed tank bikes started in 1972 and the 6 volts ran until the early 80s , as you are going to fit a choke cable take the leg shield off and see if there is a date label on the wiring. Should be easy enough to find a choke cable in your location ;)
Also check the Vin number C50E is usually the engine number ,the VIN is on the frame near where the spine rack mounts above the gear lever.
