I got a 1 litre petrol mixing bottle from Screwfix (FOC from a friend) which means I have enough space under the seat for a spare tube.
Whilst the restrictions are on its worth carrying a tube and tyre levers rather than relying on the AA.
There's not many times I find I need more power in Kent, the traffic is congested on most roads all the time. Happy days.
Hello from Lincoln, 50 yr old rides an Innova
- Rides:: Anf125, C90G, PCX125
Re: Hello from Lincoln, 50 yr old rides an Innova
Recently set up a new bag system with a 3 litre fuel can. Should take the range to 200 miles which is enough for a good days riding
Hi beware of the fuel cans that you can not fill at a petrol station ,the nozle is too big for the hole in the can .but also this may help not Innova based but all usefull .
viewtopic.php?f=42&t=5727
- Rides:: 2011 Honda Innova 125
Thank you, that all read as wise words and I'll bare all of that in mind.wightegi wrote: ↑Mon Nov 16, 2020 8:44 pmalso this may help not Innova based but all usefull .
Does anyone use a engine flush before changing the oil? or just get it hot and drain it?
Yes some do use engine flush ,get it all out ,kick the engine over a few times with the ignition off to get the last drops out then refill with the best oil you can afford .Do not start an oil debate. ..
