Hi there,
Does anybody know what screw is required for the gear change pedal on a 1990 square headlight model and where to get one from please. Mine is a chewed up Allen bolt by the look of it and I am having trouble getting the gear pedal off. Any helpful advice would be very grateful.
Thanks,
Gear change pedal.....help needed
- Rides:: 1990 Honda c90. Yamaha fizzy Kawasaki KE 125
Re: Gear change pedal.....help needed
Honda part no 92101060200A 6 x 20 hex bolt.
82p from Fowlers.
Might have the wrong pitch Allen screw put in though. I'm sure someone more qualified will be along with better advice than I could give but if it won't come out then I would get busy with a slitting disc and stud remover.
82p from Fowlers.
Hi Bikerbaker
Thank you very much for your prompt reply. I shall get one ordered and see what I can do.
Thanks again
Thanks again
Just a standard M6 bolt.10 for 57p from Toolstation.
- Rides:: HONDA SUZUKI
its just a std pitch 6mm bolt or capscrew i think its m6 1mm pitch
Thank you all for your help. Much appreciated.
Nick one out of the back of the fuel tank.
