Help please front rack
Posted: Wed Jul 03, 2019 7:06 pm
by Alang
Hi all
I have purchased a front rack complete with fitting bolts but the two bolts that bolt onto the front forks are too big. (8mm) could anyone please inform me of the correct size required and are the holes in the forks threaded ? Thank you
Re: Help please front rack
Posted: Wed Jul 03, 2019 7:35 pm
They should be M6
Posted: Wed Jul 03, 2019 8:56 pm
by Alang
Hi wightgi
Thank you for your prompt reply. Do you know if the forks are threaded or will I need m6 bolts with nuts?
Posted: Wed Jul 03, 2019 10:06 pm
by steveST100
Alang wrote: ↑Wed Jul 03, 2019 8:56 pm
Hi wightgi
Should be threaded, but may have a rubber/plastic plug in there that will need removing first.
This is the front rack for a presscub,this has two legs not the one that your rack should have,top one on this is the same as yours(m6) but this has a m8 bottom one as well.
Posted: Thu Jul 04, 2019 6:40 am
by Alang
Hi Steve
Brilliant. Thank you for the advice. I’ll look for some m6 bolts and put them in.
