1969 Honda C50 Carb trouble
St3e
Rides:: Honda c50 1969
Post by St3e » Mon Dec 11, 2017 12:18 pm
Hi everybody,
I have a 1969 C50. I am restoring it (well trying to) I am having some carb problems, I replaced the old carb with a new one I got on line, the bike idles fine but when I hit the throttle it just cuts out,, if I have choke on it won’t cut out when I hit the throttle
Re: 1969 Honda C50 Carb trouble
Post by Diesel Dave » Mon Dec 11, 2017 1:30 pm
The new carb is either faulty or the main jet is the wrong size.
What type of carb is it?
St3e
Post by St3e » Tue Dec 12, 2017 9:18 am
Hi Dave thanks for the reply
I checked the main jet today and it looked the same? So I swapped it out with the old one and was still having the same issue? Do you think I should just clean out the old carb and put it back on the bike? The new carb is lb lippo that’s all the writing I can see on it?
Post by Diesel Dave » Tue Dec 12, 2017 9:51 am
Are there no numbers stamped on the jet?
Original carbs are pretty much always better than the reproductions unless the alloy has corroded and become porous.
St3e
Post by St3e » Tue Dec 12, 2017 10:49 am
I couldn’t see any numbers stamped on it! I didn’t look very hard but I just checked to see if they where similar in size? I swapped them around but and still got the same results
barker
Post by barker » Tue Dec 12, 2017 1:37 pm
what is the size of the main jet you have in there at present
is it the right size for the carb
