Honda C50 Ran out of Fuel
spikeyboy60
Jehova Empress
Rides:: 1975 RD200A-2015 J300-1973 C70 1982 C90C 1982 Camino
Re: Honda C50 Ran out of Fuel
Post by spikeyboy60 » Mon Jul 01, 2024 7:46 am
I see that you're local to me and a few others......there's a few of us in York
If you're still stuck,just ask and one of us will pop round.
SOunds like the pilot jet might have some crap in it
Bosco71
Rides:: Honda
Post by Bosco71 » Mon Jul 01, 2024 8:32 pm
Hi
Thank you for that
Bosco71
Rides:: Honda
Post by Bosco71 » Tue Jul 02, 2024 7:28 am
Hi Again
Yea any Help in getting this Little Beast Tuned up fuel/Air mixture right will be Greatly Appreciated
Thank you all once again
John
Bosco71
Rides:: Honda
Post by Bosco71 » Sun Jul 07, 2024 11:53 pm
Hi all
Hope all are OK
If anyone Reading this Can please help me in sorting out a Carburetor issue in a Honda 50
Please let me Know(Contact)
Not Promise me & Ignore me like some on this Forum have already Done(No Names mentioned,They know Who they Are)
I very much respect Appreciate all help given
Thank you
John
Bosco71
Rides:: Honda
Post by Bosco71 » Thu Jul 11, 2024 9:18 pm
Hi All
Anyone online with Advice or Anyone in the York Area willing to help out me with a Honda c50(with Carburetor issues)
If No Replies I will break it Down & sell its parts/Spares on Ebay
It's a Shame.
Anyone with any Help will be greatly appreciated
Thank you
John
Devon general andy
Rides:: SH300 (2016),'88 C90MG,'94 & '95 C90P, '98 C90T & other 12v sq h.lt models.
Post by Devon general andy » Fri Jul 12, 2024 5:48 pm
So you’ve got a spark 👍.
Is the plug wet with fuel?
Have you taken the plug out after kicking it over loads of times to see if it’s wet? You have to take it out quickly before it evaporates… have your plug tool ready.
You need a spark and fuel. As long as you got good resistance (compression) when the kickstarter is shoved down…. Then it should fire up. You’re not flooding it, trying to start with the throttle pulled back?
Sorry that we seemed to upset you…… just trying
To help.
Cheers Andy.
Bosco71
Rides:: Honda
Post by Bosco71 » Sat Jul 13, 2024 7:09 am
Hi Andy
No Not at all Andy,(You have Been a Great Help)
Yea I got a good Spark I have New plug with a .6 mm gap.
Yea I took Carburetor off,I think I have lost bits of it.
I flushed fuel tank out, the Fuel lines are fine.
I was wondering would it work with a Different Carburetor? Maybe put a Different one on.
I have one of an old Honda Sky Scooter I don't know if it will fit. I know it was a 50cc I will try it & let you know how I get on
Once again
Thank you for all your help
John
Devon general andy
Post by Devon general andy » Sat Jul 13, 2024 7:54 am
Well, it’s hit and miss if another carb from a different bike will run the engine?
You don’t want air leaks on the joints on your metal inlet ‘manifold’. Either ‘O’ rings or if the gasket is knackered….. make one for now.
Cereal box or similar (cardboard). Cut out shape then tap round the holes with metal tool to make mark / imprint then cut out holes. Very gentle smear of grease both sides and fit between metal joints.
Air leaks here will make the engine run terrible or not at all.
If the engine runs…. You can get a proper gasket later.
I’m quite sure it was probably crap / tiny bits in your slow pilot circuit originally????
You’ve got the pilot screw out abit…… haven’t you?
Usually about 1 to 1 1/4 turns out from fully screwed in.
If you’ve lost a part….. well…. Might be knackered.
Apologies in advance if my post is patronising or taking the piss…. Isn’t meant to be.
Cheers Andy.
Bosco71
Rides:: Honda
Post by Bosco71 » Sat Jul 13, 2024 8:21 am
Hi Andy
No Not at all,your information &knowledge is very Helpful,
Yes that's good advice about the air Leaks.
I did See Carburetor for Sale on Ebay.
They looked good.but did not seem the right one.
I'm going to look online for honda Breakers in thailand/Malaysia as last time I were out their
Their was still quite a few of them on the Road.
I will try the Scooter one first will let you know in a few hours
Thanks
John
Devon general andy
Post by Devon general andy » Sat Jul 13, 2024 10:10 am
If you can't get the choke to work properly to fire the engine from cold.... then partially cover the air intake with the palm of your hand or piece of clean cloth to suffocate the carb and richen the mixture.
(don't use tissue.... tiny fibres can get sucked in).
The other way is to warm up the carb and cylinder head with a hair drier before starting.
PLEASE BE VERY CAREFULL DOING THIS SORT OF THING...... PETROL / HEAT / ELECTRICS ETC.
UNDER NO CIRCUMSTANCES DO THIS IF THE CARB IS WEEPING / LEAKING PETROL FROM THE JOINTS!!
Good luck,
Andy.
