Muddy leg and bent footpeg...
Empirical test to determine whether suddenly applying 9 bhp to a rear wheel on wet leaves will make you fall off in the car park like a twat...
Yes.....
Yes.....
Re: Muddy leg and bent footpeg...
My lips are sealed ..........for once
I'd keep that quiet if I were you Jon, you'll make yourself look a right tit!
Yes, it's that time of year. The big bikes are stashed!
Ps, presume you had an audience?
- radar
Glad you did that test Jon, I was going to do that test myself. The other empirical test I was going to do, was to perform a doughnut on wet leaves full throttle. Do you think you can try that out? just see if wet leaves help with the centrifugal force of the spin, then write a report back of the results.
- mark1982
Ive done the wet leaf doughnut quite few times in local car park it works really well just got watch out for front wheel slipping to much on leafs
who needs a bike to manage that , arce over head I went yesterday going to the shop
- buzz500
- Rides:: Yamaha xv920 Trike, Norton ES2,Honda fes 250,s90
I look like a twat anyway,with or without a bike
Buzz
Buzz
Actually no...Apart from the car parks CCTV....So I expect it'll be on 'You've been Framed Soon!Newtsalad wrote:I'd keep that quiet if I were you Jon, you'll make yourself look a right tit!
Well...Because the bike clearly wasn't square-on, was was meant to be a simple wheel spin turned into a 360 deg doughnut and as I throttled off, a little comedy highside at the end so I can safely say I've covered that one tooradar wrote:Glad you did that test Jon, I was going to do that test myself. The other empirical test I was going to do, was to perform a doughnut on wet leaves full throttle. Do you think you can try that out? just see if wet leaves help with the centrifugal force of the spin, then write a report back of the results.
- krazy kev
- C90Club Clown!
- Rides:: 12V CUB HEINZ
about a month back i was waiting at traffic lights unaware that my rear wheel was on a shiny drain lid.
i went to pull off quick and the rear wheel started to spin on the wet drain lid.
its lucky i was going in a straight line or the bike would of span round
