this i what a 12v cover looks like , this is for a dax but , it looks more or less the same as a c70-c90 12v cover, note the casing is one piece -it dosnt have a removable inspection cover. (12V)
http://www.monkeybike.co.uk/acatalog/info_1746.html
this is a 6v cover looks like , noter the cut out for the inspection cover (6volt)
http://www.cmsnl.com/products/repro-cov ... 41141000p/
this should help you identify the engines you have
and the c70 6v pistion is the same as the 12v c70 &12v c90 piston 47mm i belive .
regards matt
c70 piston needed
- matt.leese
