C90 6v top shock bracket
loadedtoad
Rides:: C90 CBR600 PE175
Re: C90 6v top shock bracket
Post by loadedtoad » Tue Jul 25, 2023 5:36 pm
That's a right hand one i think
The left hand is product number: 50306033010 and currently unavailable.
They are not interchangeable.
Assuming Left is as sitting on the bike not looking at it from the front, it's happened before :D
Also the photo on CMSNL shows what appears to be a cast Aluminium one not pressed steel.
An improvement if you can get them but i've not seen them on UK cubs.
Biglav
Rides:: C90
Post by Biglav » Tue Jul 25, 2023 6:29 pm
The shock bracket on csmnl diagram is item 6 left side.
Someone out there surely has a usable bracket sat on a shelf that's surplus to requirement.
Peter.
loadedtoad
Post by loadedtoad » Tue Jul 25, 2023 7:04 pm
As a stand in until one turns up
If you know a welder/ fabricator or machinist you could probably knock something up with a bit of tube welded to some angle iron or bar steel.
I don't think anyone takes them off unless they are painting the frame otherwise they get scrapped along with the frame.
i did see some on ebay a good few years ago but the seller wanted 50 quid for them and they were not much better than the ones in the photo i uploaded.
Biglav
Rides:: C90
Post by Biglav » Tue Jul 25, 2023 7:13 pm
That's definitely an option if one does not turn up.
Peter.
Biglav
Rides:: C90
Post by Biglav » Tue Jul 25, 2023 9:00 pm
Hi.
Ordered a pair from USA, bit more than I wanted to pay but saves a lot of messing about making one.
Thanks to everyone that's been in touch.
Peter.
