Rear repair panels for a 1975 6V C50
- Rides:: 1975. C50
I'm after the complete set of rear repair panels for a '75 6v c50 with a round headlight or direction of where they can be purchased as supplies seem to have run out sadly.
Contacts off Facebook seem to have dried up as the main Gent who was supplying them has now moved country.
Any leads welcome.
Many Thanks
Any leads welcome.
Many Thanks
- knapdog
- Rides:: 1975. C50
Re: Rear repair panels for a 1975 6V C50
Thanks I've been scouring eBay for weeks to no avail, seem to be loads of the post 1980 parts available but non for the pre 1980 sadly plus i may need the full rear section including the shock mounts depending how bad it is after I've attached it with a rotary wire brush.
- Hightechpete
- Rides:: Streamline Innova,Honda Shadow,Jialing 70,C100,Honda 400,Helix
Ebay item no.( 313692527717 ), I bought one last week for my zz90, cheap at £25 delivered in two days. Fits OK but lamp holder is different from stock.https://www.ebay.co.uk/itm/313692527717 ... %3A2332490
- Rides:: 1975. C50
Thanks, might have sorted a mudguard which looks correct just need to source the side panels now
- Rides:: 1975. C50
Thank you for the kind offer sadly that one has different rear lamp holes than he one I need, there internal where as mine an the one I've manged to locate is external
- Rides:: 1975. C50
Still on the look out for rear repair sections for a '75 6v c50 if anyone knows od any has a some thy'd be willing to sell.
I've got the rear mudguard section so just need the other 3 bits.
- Rides:: honda cubs
im looking for the same if you manage to locate any let me know i will also do the same
thanks carl
thanks carl
