C90ZZ carb wanted, 6v 90ZZ engine (if cheap!)
Cerberus73
Rides:: 2000 C90-T, 86 MZ ETZ 250, 02 Yamaha DragStar 1100A, 90 Suzuki VX800, Honda P50
Post by Cerberus73 » Mon Apr 26, 2021 2:18 pm
Looking for the correct Carb to fit my 82 C90ZZ, after ordering a rebuild kit from David Silvers, it seems my bike upon checking up, is fitted with the earlier square float bowl type of Keihin carb, with the manual choke. This carb is also missing its throttle slide and spring. I was going to chuck it into my Ultrasonic cleaner. If i can find a slide to fit, But if someone has the proper carb for a 90ZZ with the round float bowl and cable choke, and is looking for a earlier type, id be prepared to trade/barter. or buy straight out.
Also looking for a complete 6v 90ZZ engine for parts, dont care if its a runner, as long as i can get enough spares off it to put one working engine together with the existing motor, preferably a cylinder that has not got terminal fin rot, or if someone can tell me where i can get a repro barrel for a 6v 90.
