Brake & Clutch levers
hollywoodwelder
Rides:: Suzuki GSXR 750
Post by hollywoodwelder » Fri Apr 23, 2021 11:01 pm
Does anyone have a front brake lever+ a clutch lever for a 93 c 90 that they could sell me please.
Thanks for rummaging any way.
andyk1k
Rides:: 1966 S90 1998 royal enfield 350
Re: Brake & Clutch levers
Post by andyk1k » Sat Apr 24, 2021 7:40 am
Got a clutch lever measures 5" you can have for nowt next time your passing this way (poets estate)
Post by wightegi » Sat Apr 24, 2021 12:11 pm
Pit bike clutch levers are good ,and you just need to extend the left bar by 20mm to fit one.
Post by Capitano » Sat Apr 24, 2021 12:21 pm
Not something I've done nor intend to do, but just something I've wondered ..
If you fit a clutch lever on the original C90 left bar, do you have to extend it? Could you not cut 20mm off a grip end, fit a bar end and make do with a shorter grip? Or even cut down a wheelbarow type grip, and not even add a bar end? 8-)
Post by wightegi » Sat Apr 24, 2021 12:26 pm
Mine has been extended for years with no problems .
Post by Capitano » Sat Apr 24, 2021 3:00 pm
As have lots of others. I was enquiring as to whether you could add a clutch lever without extending the bar.
hollywoodwelder
Post by hollywoodwelder » Sat Apr 24, 2021 5:19 pm
I think that should be ok as it’s not going onto standard bars
Thanks for the info.
