Looking for a few parts, Tailight lens or complete unit genuine Honda only 12V C50/70/90C round lamp model. also looking for a seat base and foam or a tatty complete seat (I believe they are 23.5 inches long.. so 60cm or so long) unsure if the US passport seat is the same, look similar. so the later square lamp one is no use. also need the mounting hinge for the seat base. also looking for rickman screen for the same model.
Also looking for ignition barrel, helmet lock set for the same bike. dunno if later ones fit or not, but looking for a matched set to go on a C50 LAC frame. also looking for battery box, and side covers for the C frame, preferably original and in good nick, dont care if they need a paint. but the bikes red.
Needing a complete carb, and mounting manifold. genuine keihin PB only. not interested in the chinese clones. and a late 95-2002 on roller cam head. again must be OEM Honda, no E22 pitbike jobs. dont care if its a bit dirty, its going to be stripped and vapour blasted, same with the carb, as long as its complete and no big missing chunks. Drop me a message with anything you might have. then we can haggle the price.
as you can tell im trying to save a shed!
Wanted electrical bits and a seat 12V "C" frame
- Cerberus73
- steveST100
Re: Wanted electrical bits and a seat 12V "C" frame
This may help on the seats.
viewtopic.php?f=57&t=31846
Think the passport is the same as you want,but check part numbers if you can.
Ignition barrel, helmet lock and steering lock set is the same on both square and round headlight.
The 12v round headlight bikes have two types of backlight as far as i know,so which one do you need? I can post photos of both types if you need?
Battery box should be the same on round and square bikes.
- Rides:: ct 90 t3 cali
i have a foam a solid ish base. £40 plus post.
07976 818382
07976 818382
- steveST100
Few photos of the two types that i know of for the 12v round headlight bikes.
This is of my c50lac.
This is a c70c.
This is a c70c.
