Hi,
I have recently taken on my first C90 project, it was an unfinished restoration and the previous owners have made a half hearted attempt to strip the bike and cracked the engine casings trying to remove the rusted mounting bolts. I've tried Tig welding them, but they are beyond repair.
I am looking for a set of casings, or an engine that's past its best so I can make one good engine from two.
The only thing is it would need to be a kick start casing, as I nearly made the mistake of buying a later electric start casing, before realising the cut out for the starter motor. My bike is a 1990 on a G if that helps.
Hopefully someone can help, as i'd like to avoid going down the Lifan route if possible.
Chris
C90 Crankcases - Kick Start
- Rides:: A ‘90 90
- Rides:: A ‘90 90
Re: C90 Crankcases - Kick Start
Found an engine in need of a top end rebuild, so will start the transplant this week.
