MD 90 2003 rear shock bushes
Fat Eris
Rides:: C90P E 11/10/93 12v model code GO1 also a 2003 MD90 ex-tokyo postie bike.
Post by Fat Eris » Sat Jan 05, 2019 4:19 pm
Hi , I'm looking for a supplier for some md90 2003 shock absorber bushes , could someone point me in the right direction... thanks
Harps18TV
Rides:: 1960 Lambretta TV175, 2006 MD90 & 1978 CG125.
Re: MD 90 2003 rear shock bushes
Post by Harps18TV » Sun Jan 06, 2019 11:45 am
Hi Eris. I have just looked at my mD & the bottom bush is in 2 pieces & I assume that`s the way it should be, but I would guess that you could press a bush from a c90 shock into the eye (maybe you have some old ones kicking around?). The mounting pins are all the same diameter & a c90 shock would fit but it`s 7/8 inch shorter & not as beefy.
There are some bushes on *bay for £1.50 plus £4 postage from Taiwan that might be worth a try if you don`t mind gambling £5.50.
Fat Eris
Post by Fat Eris » Sun Jan 06, 2019 12:45 pm
Thanks for your reply .... the postage time on the bushes on the eBay listing is rather long . I'll see if there's a UK supplier..
