1984 C70 Leg shield / Leg guard wanted
Northsands
Rides:: 1984 C70C
Post by Northsands » Sat Dec 09, 2017 11:38 pm
As per title, looking for a genuine leg shield for a 1984 C70 in good condition (no cracks/stickers) - ideally in the North East of England, but I travel regularly down the A1 to London so elsewhere on that route isn't a problem. Pic attached of existing one if that helps.
Cheers, Andy
steveST100
Re: 1984 C70 Leg shield / Leg guard wanted
Post by steveST100 » Sat Dec 09, 2017 11:54 pm
Hi Andy
Remember the square and round headlight 12v models leg guard may look and fit the same but the square headlight has a lip on top that needs cutting off if you want to fit it to the round headlight model.
Bit of info on the guards on this guide.
viewtopic.php?f=57&t=31054
Northsands
Rides:: 1984 C70C
Post by Northsands » Sun Dec 10, 2017 12:02 am
Thanks a lot for that Steve, very useful! :D
Hi Andy
Northsands
Rides:: 1984 C70C
Post by Northsands » Sun Dec 17, 2017 11:31 am
Still looking! Are the cheap repro ones as bad as I'm guessing they are?
Post by bikerbaker » Sun Dec 17, 2017 11:10 pm
Last time I looked the repro ones had dried up for the square headlight bikes. They were around for under £30.
Had a couple of sets of them and they are obviously not Honda quality (or price!). The ones I have had are too white in comparison to original but do yellow up a bit after a couple of years or so. They require a bit of fettling to make them fit but boiling water, hairdryer work does the trick.
Used a heat gun a few weeks ago to try to reshape an area of one set to fit over the larger alternator of the Kayak, one last push resulted in a melted hole so had to trim round it. :lol:
If you can get them they do the job. :D
knapdog
Rides:: '95 C90 e/s, '11 CB1300, '09 NT700
Post by knapdog » Mon Dec 18, 2017 6:47 am
I had the same problem on my 1983 C70C.
If you can save your existing legshields then do so.
I also had to buy a new square headlight set and had to trim the top.
I measured carefully and used a fine toothed saw to trim to ensure a straight cut.
You'll be able to file and sand the edges to a really good finish.
Northsands
Rides:: 1984 C70C
Post by Northsands » Wed Dec 20, 2017 6:50 pm
Thanks all! Any idea if this would fit? Looks identical, although I'd rather not fork out £100!
http://www.mileskingsport.com/buy/Honda ... 4681ZA#eq1
The original is beyond repair sadly, lots of stickers and a big bit of missing plastic on the front. If I had the missing bit, maybe...but sadly not.
knapdog
Post by knapdog » Wed Dec 20, 2017 9:15 pm
Bloody 'ell they've gone up in price since I bought mine.
Post by bikerbaker » Thu Dec 21, 2017 12:55 am
The older versions are still cheap though, very frustrating!
culfy
Post by culfy » Fri Dec 22, 2017 4:33 pm
