1976 6v C90 Chainguard
Dr_StrangeTrick
Rides:: C90
Post by Dr_StrangeTrick » Sat Nov 11, 2017 4:53 am
Hi all, I'm looking for a set of chainguards to fit round headlamp 6v C90 please?
Hightechpete
Rides:: c90 zz recumbent,Harley 883R,1984 Honda Shadow,CD90,Jialing 70(aka Clown bike 2)
Re: 1976 6v C90 Chainguard
Post by Hightechpete » Sat Nov 11, 2017 1:07 pm
I was unable to find a zz chainguard, it may be of interest that the commonly available copies (got mine from M+P for around £20) can be modified to fit the zz swingarm. The mounting holes lined up ok, but a small section had to be cut out in order to fit around the lower shock mounting.
I have photos of the mod on photobucket if you're interested.
Dr_StrangeTrick
Rides:: C90
Post by Dr_StrangeTrick » Sat Nov 11, 2017 1:16 pm
Thanks, that would be handy :D
Hightechpete
Post by Hightechpete » Sat Nov 11, 2017 7:23 pm
I've marked the section that will need cutting out, tin snips should work ok.
Dr_StrangeTrick
Rides:: C90
Post by Dr_StrangeTrick » Sat Nov 11, 2017 7:29 pm
Cheers, thanks Pete
Hightechpete
Post by Hightechpete » Sat Nov 11, 2017 7:44 pm
You're welcome, just been to the garage to check and found another mounting hole will have to be drilled in the top section just behind the cut out.
Dr_StrangeTrick
Rides:: C90
Post by Dr_StrangeTrick » Sat Nov 11, 2017 7:54 pm
Not a problem for me, that tab has fell off my swingarm so I use three bolts and cable tie the top and bottom halves together (round the flanged bit)
Dr_StrangeTrick
Rides:: C90
Post by Dr_StrangeTrick » Fri Mar 09, 2018 9:29 pm
Ok guys, after waiting and waiting and waiting and countless "its on its way..." promises, "Two weeks..." messages I got a full refund from M+P
To be fair they did not put up a fight but I am still looking for a suitable chainguard so if anyone has one knocking around their shed please let me know?
Thanks again
