C70 6v Original Keihin Carb
Re: C70 6v Original Keihin Carb
Post by Diesel Dave » Thu Feb 02, 2017 1:44 pm
PhilB wrote:
Diesel Dave wrote:C70 would use either a downdraft or sidedraft carb.....
Early big valve jobbies used the downdraft.
She's an 82 if this helps.
In that case she should be a 12v (tank inside frame), does it have a round headlamp?
It could be a late registered 6v (tank separate and bolted to the frame by it's base), in which case it's the ZZ (key in the upper left side of the leg shields, has a 12v style exhaust originally and choke in the middle of the bars) The left side engine cover is a giveaway too as it has a small points access panel secured with 2 screws.
The reason I ask is; the round headlamp 12v C70C would have a reserve pipe and 2 tap connections whereas the square headlamp doesn't - you get a feel gauge instead.
Either way the chinkie chonk 90 carb will fit and it's probably closer jetted to use on a 70 so may work straight out of the box.
I can lend you one to try? if it works you can buy it, if it doesn't then send it back to me.
PhilB
Post by PhilB » Thu Feb 02, 2017 3:12 pm
Thanks for the reply Dave.
I will try and upload some pictures for you so we can hopefully get on the same page!
Also, very generous offer thanks! Will definitely consider.
PhilB
Post by PhilB » Thu Feb 02, 2017 3:24 pm
http://s1295.photobucket.com/user/Phil- ... t=3&page=1
Pass - c90club :D
P.S I thought you could see but perhaps not! The key is indeed in the left side of the legshield.
Post by Diesel Dave » Thu Feb 02, 2017 3:26 pm
6v ZZ.
PhilB
Post by PhilB » Thu Feb 02, 2017 3:47 pm
Diesel Dave wrote:6v ZZ.
Aw ok!
It didn't say that on my insurance, I think they went with a different letter, maybe C. Would this be an issue?
There was a list of about 10 different models with that plate.
Jacksond
Rides:: C90
Post by Jacksond » Mon Sep 20, 2021 10:24 pm
PhilB wrote:
Wed Feb 01, 2017 8:58 pm
wightegi wrote:They cost £170 new ;)
Second hand will be just fine :mrgreen:
Buy new where?
Post by wightegi » Sun Sep 26, 2021 1:46 pm
CMSNL are good but will charge you 20 yoyos to post a washer , and if you spend over £135 in EU land you will get taxed in this country as well ,so try a Honda dealer in this country .
