Page 1 of 2
need lots of 6V c90 parts
Posted: Sat May 08, 2010 8:41 am
by scrote
need lots of 6V c90 1973ish parts to finish off a stripped bike I'm repairing
still mending the frame but thought I would start looking for the bits now so I can get them ready
I need:
2 x complete rear indicators
whole wiring loom
kidney box that goes between airbox and carb
carb
6v horn
metal number plate bracket
legshield (need 2 actually)
whole seat
battery strap
flasher
6V coil
helmet lock
ignition switch with key
rear light lens
stand pivot pin (new ideally)
probably loads more but that's what I can think of at the moment....
would like to find someone breaking a bike so I can get the lot in one place with 1 trip but if not I'll buy them seperately
thanks for reading
Re: need lots of 6V c90 parts
Posted: Sat May 08, 2010 10:14 am
by essexalien
hi scrote there is someone on gumtree london but based in luton who appears to be breaking 90s the other week he had a full bike going for £80 anyway its worth a look.
Posted: Sat May 08, 2010 11:43 am
by Lookatrabbit
hi i have a seat if you interested its good apart from slight tare at front have pic if would like to see
Posted: Sat May 15, 2010 6:28 pm
by scrote
Lookatrabbit wrote:hi i have a seat if you interested its good apart from slight tare at front have pic if would like to see
Yes I would like to see please
Posted: Tue May 25, 2010 6:00 pm
by Lookatrabbit
Sorry about late reply only just seen yours, sorry the seat has gone but think it may have been the wrong type anyway
Posted: Tue May 25, 2010 6:36 pm
by scrote
BTTT, I still need
main wiring loom that goes along spine
black plastic kidney box that goes between airbox and carb
carb
6v horn
whole seat or 1 for re-covering
battery strap
6V coil
rear light lens
Posted: Tue May 25, 2010 7:19 pm
by Pjam
Scrote, your gonna struggle with the seat unless you get a bit of luck! my foam was braking up but it had to do and I was lucky in getting the pan made for me.
The only thing I can help with is one rear indicator! ......... sorry, it's not much but it's yours.
Posted: Fri May 28, 2010 9:37 pm
by scrote
Cheers for the offer Pjam, I'll wait and see if I can get a pair though.
also need the red 'fork cover' that sits above the front mudguard, have I got the name right?
and a straight front wheel
and an engine that doesn't smoke like hell
Posted: Fri May 28, 2010 10:05 pm
by Pjam
There's two bits and I'm not sure what to call them myself! first there's a plastic piece that sits just above the mudguard then there's the cowl with the '90' badge or park light on it.
Posted: Sat May 29, 2010 8:06 am
by scrote
Pjam wrote:There's two bits and I'm not sure what to call them myself! first there's a plastic piece that sits just above the mudguard then there's the cowl with the '90' badge or park light on it.
yeah the plastic piece I need , got the metal bit
