1986 C90e CDI unit and ignition coil
dmk10
Rides:: c90 economy
Post by dmk10 » Sun Apr 11, 2010 11:23 pm
Does anyone have the above units available which I could buy. My ignition system appears to have broken down and we have narrowed the problem down to these two units.
Fuzz
Re: 1986 C90e CDI unit and ignition coil
Post by Fuzz » Sun Apr 11, 2010 11:26 pm
A REALLY common fault is a bad connection in your ignition switch, Spray some contact cleaner or WD40 into the switch , then switch on & off a few times....
Let us all know if this has helped ?
Fuzz
Boo
Post by Boo » Mon Apr 12, 2010 12:53 am
To test the switch simply unplug it and try to start the engine. (the ignition contacts in the switch earth the cdi to stop and disconnect it to run - they can be buggers for passing a bit of current in the 'on' position and causing no spark)
dmk10
Rides:: c90 economy
Post by dmk10 » Mon Apr 12, 2010 9:35 am
Guys it is driving me crazy. I looked at the ignition switch before and disconnected that. The bike fired a few times and then cut out. For a while I was getting a nice spark but now nothing again..... I can only think the problem is with the coil or the cdi unit, but both are hard to check. Resistance in primary and secondary circuit of coil looks ok. Some of the resistances on the CDI unit aren't quite right (though that it a common issue apparently...).
matt.leese
Rides:: 1995 red 107cc c90, 1979 blue c70 zz, 1985 c90 cub blue, 1971 c50, 1973 c70z2
Post by matt.leese » Mon Apr 12, 2010 12:35 pm
dmk10 wrote:Guys it is driving me crazy. I looked at the ignition switch before and disconnected that. The bike fired a few times and then cut out. For a while I was getting a nice spark but now nothing again..... I can only think the problem is with the coil or the cdi unit, but both are hard to check. Resistance in primary and secondary circuit of coil looks ok. Some of the resistances on the CDI unit aren't quite right (though that it a common issue apparently...).
what brand is stampted on your cdi? may be a cheap chinese pitbike one which i must say are S***, , which the preivious owner may have fitted. ;)
dmk10
Rides:: c90 economy
Post by dmk10 » Mon Apr 12, 2010 9:51 pm
As my old man was the original owner of the bike from new he assures me he hasn't fitted any new parts to the ignition system! I spent time checking with a bulb today and I think the CDI is sending out a pulse to the coil. As the spark plug lead gives a nice 4kohms resistance I think the problem may lie with the coil. I'm still trying to track one down though.....
Fuzz
Post by Fuzz » Mon Apr 12, 2010 10:32 pm
Have you tried snipping off a tiny amount off the HT lead ????
